Agreed Hull Value
Um, beg to differ on how to agree on a dollar number with your insurer. Mind you, this may vary down to the individual agent/broker and underwriter, so "your results may vary". The notion is to insure the boat for it's ultimate replacement cost as determined by the policy provisions. Some policies insure for actual cash value, others for replacement cost. In reality, most are a combination. The policy limits necessary to adequately insure the boat will vary as the policy provisions vary. So, what usually happens is that the value of the loan, the surveyor's report of value, and the data sources of selling prices are considered sometimes together and sometimes individually. Practically speaking, I think the "what do I need to get out of this thing" thinking by the owner and "how much is enough but not too much to get whacked" thinking by the insurer usually results in an uncontested policy amount even if it differs between owners of similar boats. And, I have negotiated more value when adding expensive gear and less when values are dropping without going to the expense of a new survey. So, it isn't as cubic as you might expect. Well, gee, wasn't that illuminating? *zzz I think I'll go work on the boat.... Rick D.
