The only way I have ever gotten all the water out of my bilge to use the shop vac!Anyone have a switch that turns on in shallow water? I have used Rule floats for many years, but they require a couple of inches of water to pass current to the pump. Looking for less water in my bilge.
Oooo. Oooo... I've got it! Rig the shop vac to blow the water out & up like a rooster tail! You'd scare the * out of the race competition at the pre-race manouvers :dance:...I did give some thought in to permanently mounting s small shop vac some were in the stern. Doing a gravity feed drain above water line out the back attached to bottom of vacs waste bucket....
I agree on the water witch....They can be found in the defender catalog or I suppose just go to google and type in water Witch float switch...they have a metal diode that can be mounted on the wall of the bilge or on a base, but you can set the metal diodes to come on at say 1/2 inch deep...with a bilge switch that has automatic, manual, etc. by Rule Industries for instance. I'm just getting ready to buy a new one....
Brooms and warts included!Thanks for the tip guys, never heard of water witch switches. Will try them.
