Bilge pump switches
Anyone have a switch that turns on in shallow water? I have used Rule floats for many years, but they require a couple of inches of water to pass current to the pump. Looking for less water in my bilge.
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Bill, In addition to the float switch, I have a switch on the DC Panel that turns on the bilge pump by by-passing the float switch, at least momentarily. I can't remember if thet manual switch stays on continuously or if it is a momentarily switch. Look at you DC distribution panel for a "Bilge" switch.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
you might take a look at the water witch float switch.....
regards
woody
Pat
Jun 7, 2004
1,250
I agree on the water witch....They can be found in the defender catalog or I suppose just go to google and type in water Witch float switch...they have a metal diode that can be mounted on the wall of the bilge or on a base, but you can set the metal diodes to come on at say 1/2 inch deep...with a bilge switch that has automatic, manual, etc. by Rule Industries for instance. I'm just getting ready to buy a new one....
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
The only way I have ever gotten all the water out of my bilge to use the shop vac!
I did give some thought in to permanently mounting s small shop vac some were in the stern. Doing a gravity feed drain above water line out the back attached to bottom of vacs waste bucket. Maybe put it on a timer or manual a switch at nav.:+1:
Beneteau 323 Annapolis MD
...I did give some thought in to permanently mounting s small shop vac some were in the stern. Doing a gravity feed drain above water line out the back attached to bottom of vacs waste bucket....
Oooo. Oooo... I've got it! Rig the shop vac to blow the water out & up like a rooster tail! You'd scare the * out of the race competition at the pre-race manouvers :dance:
Thanks for the tip guys, never heard of water witch switches. Will try them.
I have my own warts. Maybe selll the extras as NIB on ebay.
