hey everyone, quick question, I'm redoing my old Grampian 26 and I'm getting ready to replace my bilge pump and the hose leads to nowhere, any idea on where I could/should install the output ?
I assume you are referring to a vented looploop that goes above outlet. This loop will help prevent any back flooding from the through hull, however it will reduce the output a little.
Geesh, you gotta bring up the waterline question.The problem I have is that I haven’t taken the boat out yet so I don’t know where the water line is
that makes sense to me, ok thank youIf you put the outlet 6 to 8 inches above the edge of the antifouling paint you will be OK.
