Steve
I have a 1992 H28 and noticed a little water coming out of a 2 inch drain hole in an enclosed bilge compartment just below the compression post. This is at the front end of the forward bilge compartment (not where the bilge pump is located). I poked my finger into the hole and discovered two things. 1) the water was disgusting -- my finger came out coated in a smelly black slime, and 2) the compartment went down several inches below the hole. My question is: has anyone drilled a second hole below the big one so more of the water can get out? Are there other areas in the H28 that need holes drilled to let water drain properly? Thanks for any advice.
