Finished installing new bildge pump today......this should give me a few minutes to repair a leak.
paulj :troll:
paulj :troll:
:+1:Remember you still can use the engine as I hinted to in another post, but received no comments about?
I like this system, too. Sometimes, I'll fill the bilge with fresh water and run it through the engine, when I know she's going to be sitting awhile, or every couple hundred of hours of operation, just for that fresh water flush.That is a good question. First it is an emergency procedure and would depend on your engine RPM. When I winterize the engine it sucked a gallon on antifreeze at idle in about 15-20 seconds, so at 3K maybe 9-12GPM.
Hadn't thought of this procedure for flushing the engine and bilge out, good to know you can reach the bilge with the intake hose.I like this system, too. Sometimes, I'll fill the bilge with fresh water and run it through the engine, when I know she's going to be sitting awhile, or every couple hundred of hours of operation, just for that fresh water flush.
Don't know if the original intake hose will reach the bilge. I have a longer hose attached to a 2-way valve at the strainer. The hose is coiled under the aft bunk. Pumping out the bilge involves uncoiling the hose and throwing the valve. Sucks that bilge dry pretty quickly, too.Hadn't thought of this procedure for flushing the engine and bilge out, good to know you can reach the bilge with the intake hose.
Your probably correct, it wouldn't.Don't know if the original intake hose will reach the bilge. I have a longer hose attached to a 2-way valve at the strainer. The hose is coiled under the aft bunk. Pumping out the bilge involves uncoiling the hose and throwing the valve. Sucks that bilge dry pretty quickly, too.
What I meant was, that the engine will empty the bilge quickly, so you need to stand by the 2-way valve, and put it back to the normal position before the bilge is emptied. The valve is before the strainer, and the hose has a strainer on the end. In addition, the hose has a check valve near the pickup, so that the hose is always full of water. The 2-way valve is secured in the normal position by small zip-ties, that can be easily broken in an emergency.Your probably correct, it wouldn't.
Is your 2 way before the strainer or after?
I would think you would want it before, to catch anything that might accidentally get sucked up.
