bildge discharge
roger marshutz
Where does the bildge water go when pumped on my 310? I assume to the manual bldge pump drain. Thanks
The best way to learn is to
trace the hoses. In our boat, the electric bilge pump hose runs to and through the manual bilge pump, one hose. I found that out by simply following the hoses from the bilge to the transom. There is only one outlet at the stern. Some boats have either been built or modified by POs to have separate hoses for each pump. Some use one outlet with check valves (a solution I find unacceptable) or use two separate through hulls for water outlet. Go find out what you really have.
Jun 4, 2004
19
Catalina - Myrtle Beach
Experiment
JUst pour enough fresh water into the bilge to activate the float switch and see where the water exits. Then try with the mannual bilge pump. Its a simple and informative test and also runs some clean fresh water through the bilge system(s).
