I need to replace my port bow cleat. The old one was bent for me. (Don’t ask!). I have been unable to find a replacement that will go into the existing holes. I will need to fill the two forward holes and drill new mounting holes. The new holes will impinge on the old holes (old spacing is 3.75 inches; new spacing is 3.62 inches). Flat head bolt is 5/16.
What is the best fill material? West epoxy poured into the hole (put tape over the hole exits)? Epoxy putty?
The mounting bolts go through the aluminum plate (which was not threaded). They had backing nuts with standard washers and lock washers. I had to cut a hole in the anchor well and install an inspection hatch to access the backing nuts
I plan to use fender washers and nylon insert lock nuts when I install the new cleat.
