P O left masking tape when he tried to tune up stripes on cabin. have beige tape residue all over that space. how is best way to remove will pressure washer hurt the finish on roof. residue seem pretty old. is real light beige in color
3M Adhesive remover works well and won't bother paint or varnish. Apply with rag and allow to soak in well - rub off. If it's old, use with fine scotch brite.
You are in luck. Louisiana still allows sale of this product. http://www.amazon.com/Xim-44012-Gon-Cleaner-Quart/dp/B000J4ZUWA Definitely the easy way to get the glue residue off without mechanical effort. Forget the Scotch Brite pad which can scratch your gelcoat.
It doesn't require any effort with Gon to get old adhesive off gelcoat. I used it to remove 2 year old heavy duty duck tape residue which Goo Gone and others had trouble with. It was very easy to get it off with GON. (Mineral Spirits, Xylene, and Tolulene, need I say more.) Just be careful and use outdoors in a well ventilated area. Dispose of the rags carefully by putting them in a water filled can.
i use acetone. it wont hurt the sealant but there will be a need to rewax after use. if you wax your boat. i find acetone priceless -- is necessary in boat repairs and cleanup.
so are mineral spirits and certain oils.
