best and easiest tape residue removal
29
Hunter h23 slidell, la
P O left masking tape when he tried to tune up stripes on cabin. have beige tape residue all over that space. how is best way to remove will pressure washer hurt the finish on roof. residue seem pretty old. is real light beige in color
Feb 3, 2012
72
Corbin 39 Pilothouse Cutter Lyme, CT
3M Adhesive remover works well and won't bother paint or varnish. Apply with rag and allow to soak in well - rub off. If it's old, use with fine scotch brite.
May 6, 2012
303
Hunter 28.5 Jordan, ON
I've used Goo Gone with good results on duct tape residue. It smells like something that could be based on mineral spirits.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I use WD40 for sticky things like tape and price tags.
Put it on a rag and coat to let it soak a bit.
Jul 8, 2012
146
Catalina 36 MKII North East
Peanut Butter for goo removal
No joke, try peanut butter. Leave it on a few minutes, maybe a bit longer, then wipe off the goo. If it doesn't work then go for the serious stuff.
Aug 27, 2011
408
Catalina 27 Titusville, FL
I always use Goof Off. Citrus based, has a naptha smell. Works fantastic, we use it on aircraft finishes and our boat!
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
Xylene is the chemical you want and is available at a hardware store for less than goof Off. Goof Off is basically this chemical.
Ross
Jun 15, 2004
14,693
Most of the waterless hand cleaners work rather well.
Jan 13, 2009
394
J Boat 92 78 Sandusky
You are in luck. Louisiana still allows sale of this product. http://www.amazon.com/Xim-44012-Gon-Cleaner-Quart/dp/B000J4ZUWA Definitely the easy way to get the glue residue off without mechanical effort. Forget the Scotch Brite pad which can scratch your gelcoat.
It doesn't require any effort with Gon to get old adhesive off gelcoat. I used it to remove 2 year old heavy duty duck tape residue which Goo Gone and others had trouble with. It was very easy to get it off with GON. (Mineral Spirits, Xylene, and Tolulene, need I say more.) Just be careful and use outdoors in a well ventilated area. Dispose of the rags carefully by putting them in a water filled can.
Nov 1, 2011
11
Hunter 430 Mooloolaba
I've always used eucalyptus oil for removing sticky residue. Cheap and very effective. Smells great too. Why should the koalas have all the fun
zeehag
Mar 26, 2009
3,198
i use acetone. it wont hurt the sealant but there will be a need to rewax after use. if you wax your boat. i find acetone priceless -- is necessary in boat repairs and cleanup.
so are mineral spirits and certain oils.
Dec 2, 1999
15,184
I am with "Z". Always use acetone in a well ventilated area and put it on a rag (never pour directly on gelcoat).
