Beneteau First 38 pedestal compass removal
Jan 5, 2017
2,490
My new to me First 38 has a BEN compass with no visible screws holding it on. I would like to inspect/lube etc the wheel shaft bearings . Does anyone know the best way to remove the compass?
Catalina 320 Dana Point
On most pedestals if you remove the 2 screws holding the compass light it allows the removal of the stainless cover which will expose compass mounting.
Oct 9, 2013
72
Beneteau First 38 Belmont Harbor
Hi Michael,
Please search for post titled "Need Help Refitting mid-1980s GOIOT Steering System" started on Sept 23, 2014 in the Ask All Sailors forum. Post # 9 & 10 explain how to remove the BEN (French manufacturer “Bianchetti Electronique Nautique”) Marco Polo Compass from the GOIOT binnacle.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
If its a Plastimo compass, the srews are under the kidney shaped inserts on the perimeter of the compass. Pop them off with a thin blade (carefully) and you will find the screws.
Jan 5, 2017
2,490
Hi Doug in Lakeview
GREAT pics and explanation! That will make it so easy.
Thanks very much.
Mike
Jan 5, 2017
2,490
Thanks again Doug! You're making my life too easy! I wish I was as good as you documenting the work I do!
Mike
