Bedding a marelon fitting
Feb 8, 2009
118
Sabre 34 MK-1 Annapolis, MD
Forespar's instructions for bedding their Marelon thru-hulls recommend using 3M 5200, so why would one question this? Wouldn't the manufacturer know best what bedding adhesive to use with their product?
Here's my take on your question. 5200 is likely to work, and for some reason many folks like to use it. The mfgr recommends it because, to him, there is no downside (it won't leak, and the customer has some on hand). Unlike deck fittings, chainplates, etc, in the case of through hull fittings, there is likely to be zero motion (ok, that's not strong enough -- THE FITTING WILL NOT MOVE), and so the 5200 won't be stressed, tempted to crack, or have any chance of failing.
The downside is years from now, when it needs to be replaced. With other sealants, you can remove the fitting, perhaps with some work. With 5200, you may well end up damaging the hull while removing the fitting! And when the next owner is fighting with the problem, he isn't likely to curse the fitting mfgr -- he'll only be cursing the PO's choice of sealants.
As an aside, I had to replace my engine through hull on my '79 Sabre 34. The bedding was grey, soft, sticky, putty-like, and in all respects resembled butyl. Sabre says they never used butyl below the water line, but I'm convinced it was butyl and remained water tight for nearly 30 years.
Harry
Feb 8, 2009
118
I wonder whether that might have been Dolfinite and not butyl.
You may be right. I haven't used Dofinite in over 30 years, and so had forgotten about it. But it sure has some similar characteristics. Good stuff. Come to think of it, I think I have a can around here somewhere....
Harry
Nov 22, 2011
1,278
Ericson 26-2 San Pedro, CA
Harry
Well, I haven't used it in ages, either. But if my memory serves me, the stuff stays pliable for a long, long time. Plus, it seems highly unlikely that someone would use butyl for bedding a through hull. But then, stranger things have been done!
Cheers,
Alan
Jan 15, 2012
20
Dyer Dhow, Cats Paw 10 ft, 12 ft Montpelier, VT
An interesting discussion, while sealants are not my expertise, it opened my eyes to a higher level of nuance when it comes to sealants.
I personally like 4200 and 5200 below or near the waterline. Silicone just doesn't cut it for me in those situations. I liked Maine Sails approach using 4200 on flanged seacocks and 5200 for thru-hulls alone.
To add to the fun here's a few articles that may either clarify the issue or turn your thinking to mud. http://www.goodoldboat.org/reader_services/articles/sealant.php
http://www.passagemaker.com/component/k2/item/1792-the-lowdown-on-caulk?tmpl=component&print=1
http://www.boatus.com/boattech/casey/sealant.asp
