Battery size
Oct 30, 2019
34
I'm about to buy two new batteries for Spring Fever (Mark 2 Vega) and have just thought about a dimension problem which I may have: -
The batteries are 110 amp/hr and their size is apparently 302mm long x 172mm wide x 220mm high. (12" x 6.75" x 8.66")
Having an extended battery bay, I know there's sufficient length for them overall, my concern is as to whether these longer batteries will 'snag' in the floor hatch as I slide them in? Anybody got a battery this long/high in their Vega and able to confirm it goes in?
Thanks,
Bob Carlisle
[Non-text portions of this message have been removed]
Oct 30, 2019
574
Bob,
My batteries are 13" (length) X 6.75" (width) X 9.25" (height with
posts) and I store them in the forward bilge. They are a little snug
moving in and out...but do fit.
Jack
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi.
Following advice from many on this forum (thanks again) I went out to my
Vega today to check whether the tiller (as I suspected) was not centered
correctly.
I found that the tapered pin -as predicted by posters here - was broken
and that, once the pinch bolt (with Allen key head) was loosened, the
tiller head could rotate freely.
I rotated the tiller head to what I believe is correct, based on two
criteria:
1) the tiller can now be rotated equally from the central position both
port to stbd and the stop position is symmetric.
2) the cylindrical rudder post that is secured to the tiller head by the
above-mentioned pinch bolt with hex (Allen key) head has a chord cut from
it. The new tiller position has this chord "athwartship" - ie
port-to-stbd. It was offset by about 30 degrees...
I have now retightened the pinch bolt and look forward to testing the new
configuration - along with my tp10! -...
I look forward to going for a sail when the Spring (eventually) comes..
Thanks again to all in the UK and US who took the time to offer advice..
John
V 1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 30, 2019
1,459
Simple and Fool proof method:
Before I bought my two new golf cart batteries I made up a cardboard
& tape box the same size as a battery and tried to slide it into the
compartment. After a little minor surgery under the lip of the box,
with a Swiss Army knife, the box slid in with just enough clearance.
Peter
#1331 'Sin Tacha'
Oct 30, 2019
1,459
John,
It would be wise to replace the pin, too. 'They' would not have put
one in if it wasn't needed!
Peter
#1331 'Sin Tacha'
Hello folks,Debonair (V1619) is away from me and I will not be able access her for at least a week.::).I have to replace (what the Americans would call) the house batteries and need to know what is the maximum size (in linear measurement terms) that will fit under the saloon floor - I am hoping to get two batteries of at least 75A/Hr, preferably larger, under the saloon floor, plus an existing 100A/Hr starting battery which will live below the cockpit floor.Also, I would also like to make contact with other Vega sailors who are also licenced amateurs and operate /MM.ThanksGeoff
n4lbl
Oct 7, 2008
307
Geoff:
#ygrps-yiv-1787271168 P {margin-bottom:0.08in;}I presume Debonair is 2nd
generation. Minke (2505) is and I can measure below the cabin sole
Wednesday weather permitting.
I have no plans for ham operating
maritime mobile except maybe APRS.Alan,,, n4lbl,,,
#ygrps-yiv-1787271168 P {margin-bottom:0.08in;}#ygrps-yiv-1787271168
Feb 13, 2010
528
I have two groupe 27 wet cell batteries under th cabin sole in my
boat.They are my house batteries. My starting Battery is in the
Starboard cockpit locker. That seems to work well. My Vega was
built in 73.
I am thinking to install a SSB transceiver in the fall with solar
panels. I may add another battery if I seem to need more. Doug
"Peace is that brief glorious moment in history, when everybody
stands around reloading" -- Thomas Jefferson
Oct 30, 2019
1,459
Hi Geoff,On my Series One Vega I installed, in the bilge battery compartment, two 6-volt deep cycle golf cart batteries, connected in series, for my house battery. This gives a good capacity. The only thing I had to do was whittle a thin strip off the underside of the aft end of the opening to allow me to slide the first battery aft under the floor. I went online and got measurements from the manufacturer, and made a cardboard mock-up ... just to be sure.Peterwww.mostlyaboutboats.ca
Dec 11, 2007
179
- - port st. lucie,fl.
I installed two golf cart batts in there. they are slightly taller than the group 27 but you get more amp hrs. Richard
