So what I’m gathering from all of you, is the problems with unbalancing batteries is not as much or any issue today. I would imagine higher quality controls and better building techniques would alleviate this as an issue, or at least make it rare. Ok got it 2 GC2 batteries are going to serve me well….
As for how can there be a difference between 1x6 cells and 2x3 cells. Simple… it goes back to quality control and variations between batches. I said it already there can be differences in batteries built at the same month if they are from different batches. A single battery will be built in the same batch and have the exact same chemistry through each cell. If all batteries were always built exactly the same and all batteries were built perfectly then there would be no need for a warranty because every battery would be perfect. We all know this to not be true. I sold auto parts for 15 years and while not as common in modern batteries as it was in batteries when I first started you do get bad ones from time to time.
