Charging 2 12v in parallel is not going to result in an unbalance like a series charge can.
Batteries in parallel will level each other out naturally so the unbalance effect doesn’t occur as easily.
Mike, WADR, this is simply not true. Balancing ANY group of cells, whether in series or parallel "could" potentially create an imbalance if the charging sources themselves were unbalanced.
An example of ways to best balance charging source connections to battery banks:
http://c34.org/wiki/images/4/44/Sma...ultiple_batteries_to_form_one_larger_bank.pdf
The reality is that if the connecting wires are properly sized for the load it is rare in recreational boats of our typical size (22 to 40+ feet) that the difference is even measurable between one end and the other. Batteries in any given bank are simply not that far apart to make much of a difference.
And given the fact that wiring recommendations like this link have proliferated in trusted publications pre-internet and are now so widely available on the 'net, it would be hard to find a troglodyte who has knuckles dragging so low he couldn't figure it out.
Mike, perhaps you could explain to us the difference between a box with 6 2V cells in it compared to 2 boxes of 3 2V cells wired together. [I wrote this before jeepbluej wrote his post#19.] What might have been true in days of yore is not true now. I believe the reality of what is commercially available for recreational boat use means that there simply isn't. Gazillions of boaters have proven that since recreational boating became a popular hobby/sport and that equipment for energy storage and charging has been around long enough now for the bad apples to have already fallen from the tree.
I think a greater dangers are from folks who:
--- still use more expensive $$$ AGMs when their drawbacks have been clearly documented
--- still use 4 or 8D batteries when they believe they are invincible and don't figure their backs could ever fail
--- still don't understand boat elekricity ("I don't know much about electrical on boats...") - none of us was born an electrician, we all learned; and if you are the artistic type who doesn't "do" math, then find someone reputable to do it for you and help explain it to you (not you, Mike you get it)
--- still ask about basic wiring diagrams (30 years ago, pre-internet, I could understand, now, sorry, no apologies accepted, it's all out there and there simply aren't that many different ways to do it; and we've also seen a significant drop-off in folks asking "Please critique my wiring diagram."!
--- still think combining a good bank with a bad one will help them start their engines
The good news is that we're still here to help all of them.
