I installed the Ganz 12w solar panel (http://www.defender.com/product.jsp?path=-1|328|49497|1471367&id=1648222) this spring and hooked it up with the cheap Sunforce solar charge controller I grabbed from WM on sale for ~$15. The panel is working wonderfully to keep the batteries topped off, and nearly anytime I check the controller during the day it indicates the batteries have reached the level it considers charged. It normally recharges in 1-2 days from a weekend of use.
My concern is that the controller is shutting off too early and not actually charging the batteries to 100%. One of my batteries has the built in hydrometer on one of the cells, and it never shows the green "70-100%" charge state ball, it's always showing the black "50-70% ball in the window.
The controller is very simple and non-adjustable, it cuts in, assuming the panel is outputting, whenever the batteries are below 13v, and cuts out when they reach 14.2v. I sat there with a multimeter on the main bus and saw it cut out and went from charging to charged at 14.17v (I guess I could have .03v drop to where I had the multimeter, even though it's all brand new cables and connectors, about 10ft of combined cable length & the switch from the batteries).
Am I risking damage / sulfation to my batteries because the charge controller isn't actually charging the batteries to a high enough voltage (I've read anywhere from 14.5-14.8 is often considered fully charged), or is the built in hydrometer not reliable?
If I'm not charging enough, what is the lowest priced quality charge controller that you trust? I don't care if it's MPPT or not as I get enough out of my panel already that it's reporting fully charged every day I have stopped by at lunch time.
