Battery Charge State
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I installed the Ganz 12w solar panel (http://www.defender.com/product.jsp?path=-1|328|49497|1471367&id=1648222) this spring and hooked it up with the cheap Sunforce solar charge controller I grabbed from WM on sale for ~$15. The panel is working wonderfully to keep the batteries topped off, and nearly anytime I check the controller during the day it indicates the batteries have reached the level it considers charged. It normally recharges in 1-2 days from a weekend of use.
My concern is that the controller is shutting off too early and not actually charging the batteries to 100%. One of my batteries has the built in hydrometer on one of the cells, and it never shows the green "70-100%" charge state ball, it's always showing the black "50-70% ball in the window.
The controller is very simple and non-adjustable, it cuts in, assuming the panel is outputting, whenever the batteries are below 13v, and cuts out when they reach 14.2v. I sat there with a multimeter on the main bus and saw it cut out and went from charging to charged at 14.17v (I guess I could have .03v drop to where I had the multimeter, even though it's all brand new cables and connectors, about 10ft of combined cable length & the switch from the batteries).
Am I risking damage / sulfation to my batteries because the charge controller isn't actually charging the batteries to a high enough voltage (I've read anywhere from 14.5-14.8 is often considered fully charged), or is the built in hydrometer not reliable?
If I'm not charging enough, what is the lowest priced quality charge controller that you trust? I don't care if it's MPPT or not as I get enough out of my panel already that it's reporting fully charged every day I have stopped by at lunch time.
...it cuts in, assuming the panel is outputting, whenever the batteries are below 13v, and cuts out when they reach 14.2v. I sat there with a multimeter on the main bus and saw it cut out and went from charging to charged at 14.17v...
Brian,
It appears that this charging regimen is not complete, since the bank is not seeing a continuous charge of any kind for any reasonable time period at a 14.2V level, which is required for bulk charging to get to the absorption phase (or stage). I'm sure, from your contributions here on this board, that you're familiar with the details of those three stages or proper charging, so I won't repeat them here.
Essentially, you're almost "getting there" but when the controller drops back to the 13+V level, you're not getting a either of the full bulk or absorption phases, just going back to float, then starting all over again. It seems to me that that is why you're not ever seeing a full battery charge.
Yes, 'cuz your undercharging your banks by not ever fully charging them. It's not so much charging them "to a high enough voltage," but rather charging then AT a high enough voltage to push the amps back in. Those voltages you mentioned are NOT what is considered "fully charged" since those voltages should eventually appear when you first start charging, and stay there until the amperage going into the bank starts dropping. Here's West Marine's explanation of the three stage charging regimen: http://www.westmarine.com/webapp/wc...d=11151&catalogId=10001&page=Battery-Charging
You can also read more in the Ample Power Primer, www.amplepower.com.
I'm sure you'll find a good recommendation for an MPPT controller if you do a search on that using Maine Sail as an author.
Good on you for noticing that. I guess you get what you pay for...:):):)
11,767
What you have is a simple shunting or switching regulator that basically does what you've seen, turns on and off when it hits its target voltage.. These will charge the bank to full but it takes a very LONG time even with a large array. With a small array it can significantly add to the time it takes to get to a full charge.
The combination of a panel that puts out a max current of just .78A on-top of a simple on/off regulator means your batts are going to take a very, very long time to charge.
If you figure max current of .78A for about 5 hours per day, and that is the general solar consensus, you're only putting back 3.9 Ah's per day in a best case scenario.. Another well accepted output measurement is 42% of max rated output for 12 hours of sun per day. So 12 X 0.78A = 9.36A/Day at 42% =3.9A/Day and you basically come out the same as the 5 full at max number.
If you have say a 300Ah bank at 80% SOC, an easy point for an alternator to re-charge to, that means you'd need to put back 60 Ah's to be full. However, due to charging efficiency losses, you more likely need about 70 Ah's to really get closer to full.
Simple math shows that with a need for 70Ah's @ 3.9 per day means it would take you nearly 18 days to reach a full charge. This math of course does not include ANY overcast or rainy days so you could be well over a month to replace 70 Ah's..
Also, I did not account for the shunting regulators slowness or the batteries natural self discharge which may mean your barely keeping up with the self discharge and any phantom loads like a stereo memory let alone actually putting excess charge back into the battery...
You have a solar array that can perhaps maintain the battery but will not very effectively charge it, and certainly not in two days, unless you left it already sitting at 99% SOC.
A true 3 stage solar controller may help some but not a lot because the numbers are what they are. The Morningstar controllers are excellent true three stage devices and some of the best built. They are reliable and priced fairly for what you get. Like LED bulbs there is a lot of junk out there in terms of cheap solar controllers. Morningstar is not cheap junk. A good controller may get you to at least your 5 hours/day @3.9 Ah's averaged but won't and can't work magic.
An MPPT for a 12W panel is like putting a Ferrari engine in a Yugo and you really don't have enough excess voltage in that panel to even get an MPPT to work and do what it would need to do so that would be a waste of money.
A 40W monocrystalline or polycrystalline panel, often called multicrystalline, is about the minimum I'd recommend if you actually want to re-charge in any decent amount of time. To do it in a week you'd likely want to go bigger. The thin film panels, the flexible kind, are about 50% less efficient than a mono or polycrystalline panel.
Was working on a boat yesterday with a 40W monocrystalline panel and she was putting out about 2.2A at mid day sun and was not using an on/off charger so she had a steady absorption current and was not yet to float stage. A 40W poly or mono panel will cost about the same as the thin film panel but take up slightly more room and will not be flexible.
Sorry to not have a magic bullet. If you upgrade to a Morningstar 3 stage controller it can be used with a future panel..
Apr 8, 2010
1,606
FWIW, I have about 130ah of battery, just 2 group 24's, so the small panel does much more to charge than in your example, reducing full charge time to one week (using your formula of (130 Ah bank * 20% discharge) + 15% efficiency loss = 29.9 Ah / 3.9 = 7.6 days). When adding the output of the engine, at least 1.5hrs each trip out from the dock (a little over 30 min each way out of the harbor, plus a few minutes during docking), means I do end up charging about 20% back into the bank in well under a week. Also, since I have converted everything to LEDs, I dont draw much from the bank, probably average around 10 to 12 Ah a day when overnighting, and half that when day sailing.
I did the calculations for power consumption and recharge time before buying the panel, and knew that it would take an average of 2-5 days of sitting at the dock to recharge after going out. Even at the highest use I expect to have for the boat, the batteries should not be dropping below 70%...
I had a feeling this controller wouldn't cut it. I picked it up last year knowing this would be on this years project list, but before I started researching what I would need, because it was only $15... Guess I should have saved my money... I guess I'll start looking at the morningstar controllers, where do you suggest ordering them from?
Apr 8, 2010
1,606
forgot to add, the panel outputs around 17.5v at midday, and around 15-16v at morning or late afternoon, not sure what is considered excess voltage for this scenario
I know the image on defender's site is misleading, and it looks like a flexable panel, but it's actually a polycrystaline panel, just a very thin and rugged one.
11,767
If your panel is the VPC-12 the Vpm on your panel is rated at 15.3 volts. The OCV or Voc reading is higher at 19.3V but that is a voltage reading with no loads and not one you'll see in real use with any load connected to the panel. Your max amp output is .78A.
For an MPPT to work well you really need a lot more watts than 12 and some decent excess voltage that can be sustained by the panel when connected to the load.
The only MPPT that might aid in your charging are the Genasun controllers as they are specifically built MPPT's for small panels and they are reasonably priced. The others by Blue Sky, Morningstar, Outback and others are built for larger arrays.
I still don't know that roughly 2.7 volts, if you can sustain it with a 130Ah bank, is going to convert to a meaningful amp output increase with an MPPT. Even if you could get 15% more amperage from an MPPT your still at only .1A more output.
Do you have a battery monitor?? That would be a good expenditure before buying another charge controller...
Feb 8, 2009
118
Sabre 34 MK-1 Annapolis, MD
I have heard at various times, but can't quote anything to back me up, that at some "very low" solar output level, a complete lack of controller is not inappropriate. I wonder if this is such a case? The panel is good for 3.9Ah max, and the battery is 130Ah, making the daily input only 3% of capacity before shade, charging losses, self discharge, etc.
Realistically, how much damage would be done if it were direct wired? And would it be, on balance, better than the existing controller (or any other controller that costs less than a new set of batteries)?
Harry
Apr 8, 2010
1,606
First, Thank you for the complement, I do generally consider myself pretty competent, but in this case it wasn't the case. I had heard about the different stages, but never looked into what they are or what they mean. Following your comment I decided that I better do a little more reading... Short version, I realized I really needed a good controller, and I bought the Genasun GV-4 (http://www.genasun.com/gv-4-flyer-2011-03.pdf). It arrived last night (great turn around time, and good customer service experience), and I ran down to the boat this afternoon and installed it.
Everything seems to be working great with the Genasun, it will be nice actually being able to trust the controller when it tells me the batteries are charged.
However I discovered something when I was testing everything that has me concerned. I changed the battery switch over to combine so it would charge up battery 2 (the solar charger is hard wired to battery 1), and started the engine to provide a little extra juice since battery 2 had not seen any charging in a few weeks, and I didn't want it to drain battery 1 down as a result. When I looked at the Genasun with the engine running, it indicated fully charged, so I pulled out the multimeter and measured the voltage at the batteries, and found them to be reading 16v!
It seems that the charge output from the 8 hp tohatsu outboard does not have any sort of voltage regulator. I had not noticed this before, I have only been monitoring the voltage from the solar panel and at the batteries, but with the engine off...
I am now afraid that with my batteries being properly topped off going forward, running the engine with it outputting 15+ volts while at RPM, I am going to damage the batteries. Is there a way to separate out the charging output from the engine so that it doesn't go through the same battery cable as it uses to start, and run it through a charge controller (or maybe the same one I already have)? I know on larger outboards that have actual alternators this should be easy, but mine uses the excess power from the rectifier instead...
Apr 8, 2010
1,606
So I've been doing some research, turns out this is a pretty common problem with small outboards, and most people are just unaware of it because they either never monitor their batteries when the engine is running, or their batteries are never actually charged, and just absorb the charge without a problem.
I went over the owners manual for the engine, looked at the wireing diagram and I'm pretty sure I've identified where the power is being fed back into the electricial system, so I just need to divert this into a voltage regulator or charge controller and I should be fine.
I have been talking with George aka ThatBoatGuy over at seafaring, he helped me find a new combination rectifier and regulator for a briggs and stratton garden tractor engine that I should be able to almost do a direct swap of the existing rectifier (aside from mounting, which may get trickey), and that should regulate output voltage to remain in the 13v range (exact specs on the regulator could not be found), and prevent any over voltage problems.
Beneteau 323 Annapolis MD
I have heard at various times, but can't quote anything to back me up, that at some "very low" solar output level, a complete lack of controller is not inappropriate. I wonder if this is such a case? The panel is good for 3.9Ah max, and the battery is 130Ah, making the daily input only 3% of capacity before shade, charging losses, self discharge, etc.? Harry
Page 368 of the West catalog/bible offers that if a charge is more than 1.5 % in Ah of the battery capacity, you need a controller.
