Battery 'Care and Feeding'
May 27, 2010
58
Hunter 38 Virginia Beach, VA
At what point during cruising do you decide it's time to turn on the engine and recharge your batteries? (where in the battery life) - and what do you typically charge them up to?
7,735
Alden 50 Sarasota, Florida
There are books written about this subject.
The consensus is to recharge as fully as practicable whenever approaching 50% capacity. Simple answers like this are often misleading given engine alternators can take a very long time to fully recharge so don't goby simple answers if you desire a full understanding of battery care. Buy the book(s).
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
no need to buy the book just search on this site and you will find volumes on the subject
May 24, 2004
7,228
CC 30 South Florida
My answer to that question is, at every reasonable opportunity. I'm opposed to running the engine at anchor so I will utilize opportunities to motor sail and have the engine help propel the boat as well as charge the batteries. These opportunities show themselves up whenever the boat speed might drop from our target of around 5 knots. Periodically running the engine for a few hours during the day allows us to run refrigeration and maintain adequate state of charge while helping maintain boat speed. Never liked running the engine at anchor without a load besides the waste of fuel.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
... I'm opposed to running the engine at anchor ... Never liked running the engine at anchor without a load besides the waste of fuel.
Why? I get the fuel issue, although there are plenty of arguments about the dollars per kilowatt not being all that different for running a diesel engine with a decent alternator vs. running an electric or diesel generator.
The "don't run your diesel at anchor" theory is much more of an old wives tale than actual fact. I started a conversation about this here a couple years ago. This is what Maine Sail had to add to that discussion:
About three years ago myself and a Beta dealer here in Maine had a long discussion with Stanley of Beta Marine, at the Maine boat builders show, specifically about bore glazing.
Stanley's take was this is a "non-issue" for Beta engines. He insisted they have not seen a single case of bore glazing in a Beta / Kubota block. Not a single one (as of three years ago). This is the US distributor of Beta engines and a guy who has been working with diesel engines his entire life. He is one of the more honest guys in the business and if we had to replace our Westerbeke tomorrow the guy who would get the engine sale....
He also admitted they have lots of customers who idle to charge. I suspect a lot of this is a CYA from the manufacturers point of view and with some engines there is more truth than on others..
The Universal M-25 is the same block Beta uses...... He did say that on some older Volvo's, some Yanmar's and some Vetus/Westerbeke/Mitsubishi blocks that this can be worse. That said we have a Westerbeke/Mitsubishi that has zero bore glazing and more than half its life spent idling. You simply don't get to 3600 hours on a 2002 engine, even when cruising full time as the PO's did, without idling the engine. They had no gen set and only had an 80W panel and a 50A stock alternator. The trick is after idling the PO's, and us always, run it hard.
I think the worry over this is a tad overblown if you otherwise care for and use the engine properly...
Just passing along some info.
Good luck and fair winds,
Jesse
May 23, 2004
3,319
If you are worried about charge add a solar panel into the mix. I did a 100 watt solar panel upgrade this year. It will cost about $350 but it is so worth it for the panel and the MPPT charge controller.
As others have said, don't discharge below 50% of the battery's capacity. Good advice if you know the battery's capacity and if you know how much current you have drawn.
The current (pun intended) state of the art in battery current measurement is a Balmar Smart Gauge. You can read about it here: http://www.pbase.com/mainecruising/smart_gauge
Whether or not running a diesel (or generator) in an anchorage is damaging to your diesel, sitting downwind in an anchorage when someone is running their diesel to simply charge the batteries is annoying, both because of the noise and the exhaust gas. The easy solution is to use less energy. Other solutions include reducing energy consumption (use LEDs), increase battery capacity, or add additional charging options such as solar or wind.
Don't be a noisy smelly neighbor in an anchorage.
Feb 6, 1998
11,772
If you are using a known accurate volt meter then you will want to start charging when your batteries, at your average house loads, dip to 12.2V - 12.1V. (this is a very broad generalization and depends upon many factors but 12.1V - 12.2V will keep you safe.
You will want to charge as long as you can, within good reason, especially if using the engine or genset because you hit a point of diminishing returns.
To fully charge a lead acid battery takes 8-10+ hours and this is with a healthy charge current.. To get from 50% SOC to 80-85% SOC can be done in a few hours and this is often called the "cruisers rule" of battery cycling. It is fine for a few days at a time but do get back to 100% as often as you can.
Ideally you want to charge the batteries to full as often as is humanly possible. Partial state of charge use is very abusive for batteries. The sooner you charge back to 100% SOC, after deep discharges, the longer your batteries will last.
Without knowing what type of batteries you have, or what you usage is, or what your charge sources consist of, it is tough to lay out a best course of action other than to say get them as full as you can as often as you can.
Best Practices
  • Use smart chargers (not all "smart chargers" are actually "smart")
  • Use temp compensated charging
  • Wire the batteries properly
  • Do not install batteries in an engine space or other area that can regularly get hot.
  • Do not regularly discharge below 50% SOC.
  • The shallower you discharge the longer the batteries will last
  • Use one big house bank not two split banks
  • Get the batteries full as often as possible
  • Use the highest allowable charge voltage setting from your battery manufacturer
  • If you have flooded batteries check electrolyte & specific gravity
  • If you have flooded batteries equalize them when needed
  • Know your correct state of charge at all times, even if this means investing in a battery-monitoring device. It will help in overall cycle life.
  • If you are using voltage to determine state of charge, be sure you are getting it as accurate as possible. (this is not easy for most boat owners to do)
Aug 16, 2006
281
Ericson 32 Oregon coast
A small maintenance item that can help prolong
battery life is to keep the top of the battery free of dust build up. This practice comes from car care which is more critical due to cars being in a dustier environment but it applies to any battery. Accumulated dust can sometimes be enough to create a circuit and slowly discharge a battery. I clean the tops of my batteries as part of a periodic maintenance with a damp paper towel followed by a dry one. Handle paper towels carefully and wash hands afterward as there could possibly be residual acid from seepage.
