At what point during cruising do you decide it's time to turn on the engine and recharge your batteries? (where in the battery life) - and what do you typically charge them up to?
Why? I get the fuel issue, although there are plenty of arguments about the dollars per kilowatt not being all that different for running a diesel engine with a decent alternator vs. running an electric or diesel generator.... I'm opposed to running the engine at anchor ... Never liked running the engine at anchor without a load besides the waste of fuel.
Just passing along some info.About three years ago myself and a Beta dealer here in Maine had a long discussion with Stanley of Beta Marine, at the Maine boat builders show, specifically about bore glazing.
Stanley's take was this is a "non-issue" for Beta engines. He insisted they have not seen a single case of bore glazing in a Beta / Kubota block. Not a single one (as of three years ago). This is the US distributor of Beta engines and a guy who has been working with diesel engines his entire life. He is one of the more honest guys in the business and if we had to replace our Westerbeke tomorrow the guy who would get the engine sale....
He also admitted they have lots of customers who idle to charge. I suspect a lot of this is a CYA from the manufacturers point of view and with some engines there is more truth than on others..
The Universal M-25 is the same block Beta uses...... He did say that on some older Volvo's, some Yanmar's and some Vetus/Westerbeke/Mitsubishi blocks that this can be worse. That said we have a Westerbeke/Mitsubishi that has zero bore glazing and more than half its life spent idling. You simply don't get to 3600 hours on a 2002 engine, even when cruising full time as the PO's did, without idling the engine. They had no gen set and only had an 80W panel and a 50A stock alternator. The trick is after idling the PO's, and us always, run it hard.
I think the worry over this is a tad overblown if you otherwise care for and use the engine properly...
If you are using a known accurate volt meter then you will want to start charging when your batteries, at your average house loads, dip to 12.2V - 12.1V. (this is a very broad generalization and depends upon many factors but 12.1V - 12.2V will keep you safe.At what point during cruising do you decide it's time to turn on the engine and recharge your batteries? (where in the battery life) - and what do you typically charge them up to?
