Rob Rich
I have an Atomic 4 onboard my C-27, with a starter battery for the engine and a dual purpose for running the toys. The new dual purpose (under the port settee)works great. I found that the cable running from the engine to the negative terminal is exposed in several places, and needs to be replaced badly. It is even bare in one area. Two questions:A) Where does one find a 10 foot battery cable? West Marine and auto stores do not carry them, and my wire crimper is not that big. Home Depot does not carry 6 guage wire either. A friend recommended GrayBar, and they may be my only choice.B) What do you suppose could cause the coating on the negative cable to deteriorate so badly? In one area it is gone completely. I suppose heat from a short, but has anyone else seen this in cause-and-affect form? I am surprised the former owner didn't blow up. Looks like this is the orginal cable from the factory. p.s. - the boat has stayed on the same freshwater lake for its entire life, so saltwater doesn't enter the picture.
