Battery Cables
Shippy
Jun 1, 2004
272
Hunter 356 Harve de Grace
I need to learn all I can about battery cables, including sizing, installation and a good source to buy. I need to change out the existing cables on a boat I just bought to something larger. The house bank was added by the PO and during the inspection, my surveyor pointed out that the existing cable (6-AWG) to too small. The bank consists of four Trojan 6v batteries. The distance between the batteries to the charger and battery switch is probably (haven't measured yet) 8-10 feet (one way). Is 2/0 marine grade battery cable teh correct size? I'm guessing I'll need customized cuts of both black and red cables, so how do you crimp the ends to button connectors?
Benny
Not necessarily too small.
The gauge of the cable is directly related to the current that must go through it (the load). If the load draws more current than the cable can carry the cable will heat up. Turn on all the lights, radio, water pump, 12V fans etc. See if the cables heat up. If they do then you need to upgrade as you would have a potential fire hazard in your hands. If they remain cool their capacity to carry your load is adequate. They estimate the safe allowable current in amps for the cabin of a boat is 80 AMPs and for this current with a conductor wire round trip of 10 ft the recommended wire would be #6 gauge. If you were to double the conductor wire to a 20 ft round trip the #2 gauge would be recommended. 80 amps is a lot of juice and I doubt very much your maximum combined load would even aproach half of that. You can run 40 amps trough a conductor wire round trip of 30 FT with #6 gauge wire. Engine starter loads are larger so a #2 gauge wire would be recommended for the starter circuit; if your house bank is connected can be called to act as a starting bank then you should upgrade to #2. But if your house bank is a stand alone dedicated use then it would seem that what you have is adequate. There is a formula for sizing wire: CM = (I*L*10.75) / (E) CM= Wire size in circular mills I = Current in Amps (load) L = Length of wire Round Trip E = Allowable voltage drop- generally 0.36 Size Conversion Table CM Wire Gauge 1,620 18 2,580 16 4,110 14 6,530 12 10,380 10 16,510 8 26,240 6 41,740 4 66,350 2 83,690 1 105,600 0 133,100 00 Figure out the consumption load in amps of all your componentes that may be running at once and plug it in the formula. Measure the round trip distance to your battery switch and round up to an additional 5 feet and plug it in the formula. Get your CM and find the corresponding gauge size. I have seen dedicated house batteries in a daysailer safely using a #10 gauge. It all depends on the loads and the way it is wired.
Jun 6, 2006
6,990
Benny is right
but don't go turning everything on to see if the cables get hot. You could start a fire. The load to design for is the max current you would ever put through the wire. This does not have to be "everything turned on at once". You are not going to have the anchor light and the running lights on at the same time. The same goes for other loads. Without knowing what equipment you have on board it is hard to advise you. The max load is usually the biggest single load plus all the other things that are on when the biggest load is turned on. Inverters running hair dryers and starter motors come to mind. You do not have to power the starter motor and the inverter both. This could mean that you have adequate wiring (or not). What equipment besides the normal running, anchor, cabin lights stuff do you have?
Don
consider voltage drop too
In addition to what Benny and Bill said, you may have sufficient size cables as is depending on your max load but there is a point at which the voltage drop becomes too great. If you follow Benny's formula, you will be right but check the total voltage drop to make sure as if it becomes too great, you could effectively increase the current load on a marginal cable. Don
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
That depends!
First, I would recommend that you verify anything you read here from some authoritative source, including the potentially wrong and life threatening advice I may give you! West Marine has excellent technical resources on this topic. Their information is based on the ABYC standards. Two things of immediate interest are Marine Wire chart and the Electrical Budget Worksheet that are found on this here: http://www.westmarine.com/webapp/wcs/stores/servlet/WestAdvisorListView?storeId=10001&langId=-1&catalogId=10001 For your application your biggest current load may be the alternator to battery charging wire, connected to the B+ terminal on the alternator. Assuming a heavy duty alternator and external "intelligent" regulation, this could exceed 100 Amps. On my boat I have a 125 Amp alternator and I can see 100 Amps plus when I begin charging a bank that's down pretty far. Also, if you have a windlass, this can be a load in the 100 A neighborhood. Your shore power charger is probably not a big concern, as these are typically in the 10 A range. You still should make sure the wire is properly sized, and protected. A wiring system that is properly protected with fuses or circuit breakers should never cause a fire. I don't know where the supposed 80 Amp limit comes from, Benny, can you provide a reference? My friend's electric bow thruster on his 53' sailboat draws 750 Amps in use! Additionally, there is no "typical" allowable drop, it depends on the class of load. ABYC puts them in two classes, 3% and 10%. See the West Marine chart. Crimping is accomplished with - a crimper! There are several types, and for this wire size all are expensive. The least expensive is the one marketed by Ancor and sold in West Marine that you smash with a hammer to cripm: about $65.00. The one that looks like a bolt cutter is probably around $300. Maybe the boat yard can do it for you. At my yard they won't lend the tool, but if you bring the guy the wire he'll do it for free. If he has to go to your boat, it's $70/hr. I don't know what a "button connector" is.
Sunshine
Pay attention to the sailors
and not to the boys in the science club.
Ross
Jun 15, 2004
14,693
Sunshine, You are starting to get my attention.
Men of science understand terms like: power density, Ohms per unit length, voltage drop, amperes. Sailors may also under stand these terms and some may be able to apply them in a useful manner. If you disparage knowledge in favor of intuitive thinking you run the risk of leading others into danger.
Jun 7, 2004
383
Schock 35 Seattle
Be safe
When I wired a previous boat I read articles on wiring, sizes, etc. Then I wired all 12 volt with 1/0 wire and had West Marine crimp on the appropriate fittings. May have been too bid, but I know it was not too small.
Shippy
Jun 1, 2004
272
Power draw
probably the biggest draw is the windlass, refrig/freezer and/or battery charger Truecharge 40+. Besides that everything else are pretty light draw stuff (lights, radio, vhf, gps, etc). My surveyor was definitely under the mind set that the 6 AWG was undersized and should be replaced immediately. The west advisor is helpful, but looks like I have to figure out that max draw first.
jviss
Feb 5, 2004
7,090
DC Clamp-on Ammeter
Best Christmas present I ever got is a multimeter with a current clamp that reads AC and DC Amps. I measured the current for everything and wrote it in my log book. What kind of alternator and regualtor do you have?
Dec 2, 2003
4,245
- - Seabeck WA
Shippy,
These guys are GOOD! One more thing; always error on the side of caution. With wiring that means 'bigger'.
Scott
Funny coincidence!
I just came back from West Marine just now and I bought a red and black cable. It is an item that is a bit more pricey than I expected! A 48" Red 2-AWG was $46. The 16" Black 2-AWG was $37. They were packaged in 16", 32" and 48" lengths. If you have a greater length, I suppose you would have it made. I measured the old cable to to get the right length. I'm only replacing the cables from the starter to the switch on the positive side and from the neg battery post to the engine block on the negative side. The other cables don't look so bad so I didn't replace them after choking on the price (I am going to do some further scrutinization). I scratched my head in the store for a while when I was trying to think if I was replacing existing #4 or #2. Visually, I couldn't see much distinction so I figured I would take the larger wire to be safe even tho it was several extra $$$! BTW, I have a 27' boat with a 1GM engine, probably with the original alternator & starter (which I don't know what size or capacity they are).
Ross
Jun 15, 2004
14,693
I do hope you got kissed when you bought
that battery cable. Jamestown distributors sells ten foot rools of 2 gauge red or black for 21.19 USD Edited; to correct name of supplier.
Hunter 34 Seattle
Welding Wire
I used 100A welding wire for less that $1/ft. I know this is not approved wire for this type of use but it has been in for 5 years with no problems and it is also oversized. It is not tinned but I sealed each fitting with glued heat shrink to keep out moisture. There is also some concern about the possible lighter insulation cover on the wire. I have it all anchored in place and have seen no evidence of chafe. I figure if it can withstand shop floor use, it should work on my boat. One other advantage I found was the flexability of this cable as compared to the marine grade. I am not recommending this type of wire to be used, but I am planning to add two more golf cart batteries and will use it again.
Scott
Ross, I get some gift certificates ...
when I spend more money there ;). As a typical boat owner, I get pulled by gravity towards stores that sell boaty things :{ Hey Fred! Why are you avoiding the "dark" side. You're missed in there. I know, I was pretty mellowed out after vacation for a while, too. But your absence is really getting noticeable ;) I hope your cruise was great! :)
Shippy
Jun 1, 2004
272
Ross
Ross, do you have contact information for these guys? I couldn't find them on the web....
Ross
Jun 15, 2004
14,693
Skippy, try this link
http://www.jamestowndistributors.com/userportal/main.do;jsessionid=6A0841753D77AF89E2CA86D4AFF163B6 Or this one http://www.hamiltonmarine.com/
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Last time I looked (about 5 min. ago) # 2 was 32.84 so thats 3.28 a foot copper price's change faster than I change my socks!! I just replaced some cables with 2/0 and what I did was go to my mom & pop auto supply store and they made up the cables with crimped eyes on each end and then when they looked up the price he says this is way to much and adjusted the price down,I think with all this rain this weekend I might replace some more and hope he does the right thing again. I paid 9.00 a foot with the labor to crimp included and WM wanted 12.50 a foot just for the cable
What can anyone do with 2/0 cables
on a boat unless it's for a (say, a Freedom) combined inverter charger connections to the battery banks? There is a BIG difference between 2/0 and #2. #2 makes sense, but 2/0? Are we just mistaking the gage of the wiring here, or is somebody going WAY overboard? NPI
Benny
RAD are you running a windlass?
2/0 is some serious power transmission cable. Most people will place a dedicated battery up near the bow to significantly reduce the wiring round trip distance and hook up a solenoid or relay to energize the circuit via a bow or cockpit switch.
