Barlow winch replacement
Mar 28, 2007
637
Oday 23 Anna Maria Isl.
Like Ziradog, I too have some issues with my Barlow winches on an O'Day 23 - 2. Can anyone recommend a direct bolt on replacement? Thank you.
992
Oday 25 Gibraltar
I replaced my Barlow with Lewmars which also had 5 mounting holes and different centers. I installed the new winches by placing the new bolt holes between the old holes. There's more than enough fiberglass "meat" in the space between the old holes. To be on the safe side you can put a large backing plate and fender washers underneath. I used 1/4" ply.
992
Oday 25 Gibraltar
I got the No. 16 two speed but I think that the No.8 single speed would have been adequate
Ward H
Nov 7, 2011
3,843
When installing my new winches on my 25, I found plywood reinforcement already imbedded under the winch area. Not sure if the 23 has the same or not.
Check the manufacturers websites. They have sizing charts and templates for the hole patterns.
