I just loaded it into a clean soup can and placed it on the stove til it melted.... it was too hot to handle without glove. about the same temp as candle wax would be...As to the power leads there are only two wires in the power cord. they go to your 12v cabin battery. these units don't run on self contained batteries. the other cable goes to the transducer.
I like the way Centerline set up his unit, but these Garmin transducers are so long that I doubt you'd find a piece of pvc suitable. I just played with a piece of 4" pvc, but it couldn't be formed large enough to go over the unit. If I end up mounting mine inside the hull I think I'll cut up one of the containers shown below. lots of different products come it this size and shape from soap to fix-all and plaster products, and it gives plenty of room for the long skinny Garmin transducer.
Centerline: how hot did you have to get the toilet bowl wax to make it flow?
long before waterproof leather footwear, my dad used to buy toilet wax to melt and oil his cork boots with it (this will be pronounced "caulked" boots for all you non loggers
just heat the boots in the oven on 200degrees and when the leather is warm, it will suck the melted wax into it like a sponge.... this made them waterproof for a few weeks,.. and then when they dried out, you could reheat them and it would allow the wax to soak around and make the boots waterproof again
