First the issue, then several questions:
Today, I poured some diesel from a jerry can into the fuel tank. After pouring it in, and after having run the engine for a few minutes, I noticed that the can has what looks like brown sediment in its bottom. I assume it's some sort of growth. This is despite always using biobor.
I checked the sediment bowl on the motor, and it has just a little bit of this same sediment in the bottom of it.
My questions:
1) What is the best way to clean the jerry can?
2) Do I need to worry about the fuel in the boat's tank? Should I get it polished and get the tank cleaned? (There's about $50 worth of fuel in the tank.) I should note that the boat is a 1998 and I doubt it's ever had the tank cleaned. The boat is in the SF Bay.
Thanks for any suggestions.
My questions:
