Backing plate support for rail stantions
Ross
Jun 15, 2004
14,693
If it is 3/4 inches thick minimum with large fender washers under the nuts.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Generally, fiberglass is a much better idea. Marine Plywood can rot and isn't as good at resisting compression IMHO. Making up fiberglass plates is pretty simple to do.
Jun 26, 2007
106
Freedom F39 Lyttelton New Zealand
Thank you MrBee, a very useful phrase. IMHO some kind of hardwood, I am not sure what is available in your area, would do a good job as a backing pad for stanchion bolts, with penny washers as suggested earlier. I use baloo or jarra at least 1/2" thick for this sort of job.
