Greetings,
I bought this Ericson and have only been out on her 6 times.... Absolutely love the boat but get a tad up tight when taking her out of the slip... I have a 60% track record of a perfect exit but the other 40% leaves a bit to be desired and in fact have ended up sideways in the fairway. The actual departure from the slip is easy but the process of going from reverse to forward is where the boat does not respond to rudder direction. I have read that prior to leaving reverse (or neutral) that the rudder should be turned to the direction of desired forward travel and then place in gear and give a couple of short bursts of thrust to make the rudder bite..... These sound like good ideas but was hoping that I might here from some experienced folks. I do know that having the prop so far forward of the rudder produces some unique challenges....
Tim
Tim
