Mark Rickey
We have a new (2007) Beneteau 43 with the Jabsco manual toilet in the aft head. I have had backfill to the bowl problems since I recomissioned it this spring. I have checked the flapper valve as well as the joker valve, cleaned, used vegetable oil, etc. and still have backfill. Then i changed the joker valve and the backfill problem went away...for a few weeks. Now it is back. what else should i check?
Also, we don't use raw water to fill the bowl. In fact, the raw water through hull is closed and we use fresh water from the shower instead. The intent here is to keep the odor of Chesapeake Bay water out of the boat. Despite that, I am beginning to smell that smell under the starboard seat cushions, that I had on my old Hunter 34. Do I need to replace the hoses already?!?!?
This is new equipment. I would expect it to work for more than a year.
Thanks
Thanks
