I'm trying to fix a slow leak which shows up in the area where the the hot water tank drain empties into. I know it's not the drain because I put a cup under the drain hose and it's dry. The water appears to be coming form the weep hole to the right of that drain, which is odd because that hole should be for water in that area to drain out and down to the bilge. The area where the water manifold and pump is located is dry., as are the adjacent bilge area.
