Autopilots
A rudder gain of "2" is generally adequate for most cruising boats of this class.Remember this is an electro-mechanical feedback control system & is sensitive to all the external forces acting upon the boat. Excessive input (forces) acting over too short a time (repetition period) can drive the system into an unstable condition (oscillation, or wandering). The rudder gain setting attempts to establish the optimum damping under most conditions -- setting it too low will result in long response times, setting it too agressive will result in "hunting" around the desired course line and even over compensation (can cause a jibe).My experience (Cat320 with ST-4000) suggests the system is fairly sensitive to sail trim. Too much weather helm with a low rudder gain setting will cause wandering, as will just the opposite with too agressive a setting. With a heavy lee helm, you're in trouble either way. Getting the helm/sails balanced before engaging the autopilot is a good practice (and it conserves much battery power). When helm/sails are well balanced, any rudder gain setting will work well (for a while).One final thought -- we tend to set the autopilot to track to a heading, but they can be used to track to a wind direction (if you have the interconnected wind instrument). Tracking to wind angle is generally easier on the system once you get that balance. This wind angle tracking mode is especially important if you are running downwind, as will tend to prevent jibes. However, the crew must be sensitive to wind changes relative to the direction they will take you.--Ron
