I have a raymarine st4000 autopilot on a '07 Hunter 33.
It appears the st4000 operates in two speeds. Often it runs only in the slower of two speeds turning the wheel very slowly. It runs so slowly, that in the slow made the boat cannot not successfully tack when using the autotack mode.
The belt is properly tensioned. The batteries are charged, and this occurs even if the engine is running and the alternating creating proper current.
I have changed the sea state mode, and the rudder gain. Rudder gain is set to maximum at the moment, but the setting has no apparent effect on the speed of the operation of the wheel motor.
Any clues on what the problem could be?
