I'm up for a new autopilot and thought id see what others are using with similar boats.
My boat is a Hunter 430 that had a CPT wheel pilot. It worked ok - until last weekend. I took it apart and it looks like I need a new Autopilot.
All nav electronics are Raymarine, thinking of sticking to the same brand but would consider other brands as well.
Question: if you have the same boat, what type of drive do you use?
Any suggestions what drives and autopilot types to use or not to use?
I had a look at a few options.
- Raymarine Evolution Wheel Pilot seems the cheapest option but it's only rated to a max displacement of 7,500kg. The Hunter 430 is about 10,000kg. So I guess that's out of the question. Or is anyone using these on their 40plus footer?
-The linear drive option looks good but I don't think the drive will fit without having to do some surgery.
- Some hydraulic options from B&G could potentially fit. A bit pricey though.
- Rotary Drive seems the only option I can think of.
- Any other suggestions?
