My 2005 C36 MkII is equipped with a Raymarine 6001 below-decks autopilot. Toward the end of last season the autopilot developed a problem where it would either fail to engage from standby mode or drop out to standby after a couple of minutes in operation, but only when the motor is running or is turned on. It works perfectly when under sail only.
Solution turned out to be replace the control head. Not inexpensive but less expensive than replacing the computer as well which wasn't necessary in my case.
