Fluxgate location
In the front of the bilge, just under the cabin sole. Had to make a small filler block to give it something flat to attach to. Originally it was in the aft end of the bilge, but had to move it. I thought mine was okay in its first location until the bilge pump kicked on the first time, and the boat took an immediate 90 degree turn to starboard. Very exciting.Sooo ... if you mount your fluxgate in the bilge, stay away from the pump itself. To test your proposed location, turn the power to the autohelm on and move the fluxgate forward and aft in the bilge while someone watches the fluxgate display on the control head. Try not to rotate the compass too much so the heading stays relatively stable. If you get too close to the pump, the display will begin to change rapidly. Now attach the compass in its proposed location temporarily, then turn on the bilge pump and watch the display. If it doesn't change, you're far enough away.
