Jack
The bolt broke that holds the alternator bracket in place. I see from the archives that it is a common problem on 85,86 M-25 engines. Mine is an 1986 M-18. I was wondering if the upgrade alt bracket kit for the m-25 would also fit the M-18? From the pictures in the archives it sure looks the same. I need to back the broken bolt from the manifold this morning and as a temporary fix I would replace the bolt with another. Is there any metal issues between a new bolt and the engine manifold on the short term? Can I simply match the bolt with one from Home Depot until the kit arrives or can I cause some type of metal on metal issues with a cheap Home Depot bolt? as always, "THANKS" jack
