Anyone heard from MaryC?
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
She/they were on a trip from Grand Rivers, KY to Mobile., AL in mid-Nov and had asked about her 280 engine performance.
MaryC
Sep 30, 2008
27
Allmand 31 Grenada
We made it to Mobile
Hi- thanks for asking. We made it to Mobile! We had a bit of trouble when we left Demopolis. We were headed to the lock and a bunch of boats were waiting for us to get there. I decided to push the engine to 3200 rpm, after about 5 minutes the engine overheat alarm started blaring! We managed to limp back to Demopolis. Turns out the raw water seacock and strainer were both nearly completely clogged. I will admit I did not know to check them.
Anyway I cleaned them out - and ended up waiting a few days for weather, and then started again. This time she ran like a charm. I was able to run her easily at 3200 RPM for the rest of the journey. I learned a valuable lesson.
I've been encouraged to change out the little raw water strainer that came with the boat for something larger since I will now be traveling in salt water. Curious to know if anyone else has found the need to do this?
Thanks,
MaryC
Oct 29, 2005
2,366
Thanks,
MaryC
Do you have a hull strainer for your raw water intake? If no, do have one install. It'll prevent the likes of plastic bags and leafs/seaweet get suck in to the inboard strainer. I doubt larger inboard strainer would be of any help.
