I actually saw a boat down in the Keys where the owner had modified a wall unit into a pseudo-central unit! I don't remember exactly what kind of boat it was, but was around the 25-28 foot range and was being used as a live-aboard. Basically, they took the guts out of the wall unit, mounted it in the rear bilge under the cockpit area on a custom built platform with rubber isolators to minimize vibration. Duct work was then fabricated to feed the supply air into the cabin, and a return line was cut through the rear bulkhead where a regular home a/c filter was installed. It worked fantastic and kept the boat super cool even on the hottest days. To top it off, I remember the owner telling me that the total cost (less his labor) was about $30 for stuff he had to buy.. the A/C itself was a unit someone was giving away for free and most of the material used was scrounged from dumpsters at local construction sites.It is not worth it to try and convert a window A/C unit to be used on a cabintop hatch. Have seen a few attempts and none worked efficiently. The main problem is air circulation.
I am doing that to this AC unit. I ordered a 135 cubic feet per minute blower to pull air in through a cowl vent and push it out of another cowl vent. When it got here it had been dropped and was seized, I had to send it back. I got it for $22 including shipping, too bad it was bad. I have marine AC that works great, I was building this partially as an experiment and to have something that will run off of a Honda 2000 generator.I actually saw a boat down in the Keys where the owner had modified a wall unit into a pseudo-central unit! I don't remember exactly what kind of boat it was, but was around the 25-28 foot range and was being used as a live-aboard. Basically, they took the guts out of the wall unit, mounted it in the rear bilge under the cockpit area on a custom built platform with rubber isolators to minimize vibration. Duct work was then fabricated to feed the supply air into the cabin, and a return line was cut through the rear bulkhead where a regular home a/c filter was installed. It worked fantastic and kept the boat super cool even on the hottest days. To top it off, I remember the owner telling me that the total cost (less his labor) was about $30 for stuff he had to buy.. the A/C itself was a unit someone was giving away for free and most of the material used was scrounged from dumpsters at local construction sites.
Cheers,
Brad
That may not be a fresh air intake, that is probably an exhaust if it has only one vent tube connected to it.I made hatch boards for my Catalina 30 out of ply wood and fabricated them to fit the window unit.
The window unit worked okay (even though it was over 10 years old). The boat cooled after some time had taken place.
The negatives were there though. It was an absolute pain in the butt to try to get around the AC unit when going into the boat, It was heavy and bulky to move and store, and I always had a wet cockpit floor from the drainage.
I have been thinking about buying one of those AC's from Wal-mart that are stand alone. All they require is a fresh air intake which you could easily fabricate. You could also design it so that they water would run into the bilge.
