Any warnings for purchase of 2000 Hunter 460. Especially regarding age of standing rigging
Jul 16, 2016
2
Hunter 46 Los Angeles
Looking at purchase of 460. Survey this week. Already had rigging inspection and did find some frayed wire strands . Both sides at lifeline contact and one side where the wires cross at the spreaders.
Also the rogger doesnt want to inspect the headstay saying it requires removing the foil.
Will failure of that stay cause the mast to fall ? Has any one heard of occasions of that happening? Has anyone heard of changing that stay without demasting the rig?
Rick D
Jun 14, 2008
7,207
Yes, in fact there is a current article in Cruising Outpost regarding a failure of a cotter pin in the headstay of a 430 causing the pin to fall out and headstay to fail thus demasting. I think pulling the foil is a really good idea.
Likes: Chevy1217
Oct 29, 2005
2,366
Don't forget the mast chainplates. My 14yr old boat broke a stud bolt. Found out by chance of redoing earth bonding.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
that boat is 16 years old now...and standard recommendation for changing out the standing rigging is 10 years...and you have no active knowledge of the rigging to begin with ....if you haven't made the final deal yet for the boat ....get the replacement cost for the rigging installed including the cost of the rigging and split the cost with the seller in the deal or try to get it all done in the deal ...just food for thought ...good luck
Likes: Ggarber
Rick D
Jun 14, 2008
7,207
Anyone have any idea what the re rig job should cost in San Diego??
Looking at $$6-8K. I wouldn't run out and do that. Have your own second opinion. IMHO.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
it's not that much considering the price of a boat like yours ...about 3% of the price ......get bids.....oh and by all means get a good survey by someone with no connection to the broker or seller
Sep 8, 2014
2,551
The survey might tell you more... but if I found ANY 'frayed' wire strands... those are 'broken' wire strands, I would be replacing the standing rigging. Any broken strands. especially at the base of any swaged fitting, is evidence of crevice corrosion. At 16 years, if still on the original rig, and we are talking 8K on a $150 K boat... yes, replace it.
- Yes, you can replace stays with the stick still up. You might want to consider a full mast service... If the mast is un-stepped and laid on stands other important work keep be done, like checking all hardware and replacing isolation/lubrication on stainless hardware. Nothing drives me more insane on a hull that 'young' than finding a ton of crusty corrosion all over the mast hardware.
- On a masthead rig you don't always have failure if you loose one stay, but if its the forestay or the backstay that goes it is more likely. With that kind of investment (and a discount on your insurance), best peace of mind is to go with new standing rigging... You'll be good for 10 years or more and you won't have that sneaking gut feeling every time you sail that one stay you are unsure of could part without warning.
