Looking at purchase of 460. Survey this week. Already had rigging inspection and did find some frayed wire strands . Both sides at lifeline contact and one side where the wires cross at the spreaders.
Also the rogger doesnt want to inspect the headstay saying it requires removing the foil.
Will failure of that stay cause the mast to fall ? Has any one heard of occasions of that happening? Has anyone heard of changing that stay without demasting the rig?
The survey might tell you more... but if I found ANY 'frayed' wire strands... those are 'broken' wire strands, I would be replacing the standing rigging. Any broken strands. especially at the base of any swaged fitting, is evidence of crevice corrosion. At 16 years, if still on the original rig, and we are talking 8K on a $150 K boat... yes, replace it.
- Yes, you can replace stays with the stick still up. You might want to consider a full mast service... If the mast is un-stepped and laid on stands other important work keep be done, like checking all hardware and replacing isolation/lubrication on stainless hardware. Nothing drives me more insane on a hull that 'young' than finding a ton of crusty corrosion all over the mast hardware.
- On a masthead rig you don't always have failure if you loose one stay, but if its the forestay or the backstay that goes it is more likely. With that kind of investment (and a discount on your insurance), best peace of mind is to go with new standing rigging... You'll be good for 10 years or more and you won't have that sneaking gut feeling every time you sail that one stay you are unsure of could part without warning.
