recent post from the trawler forum, about what happened to his engine:
" On our multi-state trip home disaster struck. My fault, I got stuck in low tide not watching what I was doing. Boat listed pretty good to starboard. I tried backing out but heard the props scraping the mud and knew it was too late so I stayed put, dropped anchor. I shut down so that I would not clog the strainers and decided to wait it out. Tide comes up and we get unstuck but I can not start port engine. It doesn't even turn a revolution. Next day I check oil level and it's overfilled. Suspect some sort of hydrolock - Call CAT for emergency service ($$$). Due to the severe angle of the boat water entered the crankcase from the muffler through the turbo outlet. We drained and added new oil. Still unable to crank. Then removed valve cover & injectors on the starboard side of the port engine and found no water in cylinders. Tried cranking with those 4 injectors removed and again no cranking. I will add that we also removed much water from the muffler and opened up the exhaust manifold to remove more water. Still can't crank this engine. We then tried to manually rotate crank with big breaker bar. We were able to but this was very difficult (much more than stb. engine to compare). Something is still preventing the crank from turning easily. FYI, I am able to rotate prop shaft while in neutral so no restrictions underneath.
The only thing we have not done is check for water on the port side cylinders of this engine. Our thought is that we hand cranked the shaft enough to remove any remaining water.
The CAT guy is stumped. He returns Tuesday to put things back together. Called a few other folks and got them stumped too
All was going so well on our way home after 4 good travel days (including transit through the East River & Hell's gate) but now we are stuck on the upper Hudson. This has been a tough, expensive nightmare and not sure how its going to end but I am starting to worry."
----ultimate diagnosis for his expensive caterpillar turbo-diesel engine , anyone ? ---
