Another New Project That might be of Interest
942
hunter 356 Kemah,the Republic of Texas
Just a follow-up to the installation.
It works great, so no more removing the whole pump assembly to access the impeller.
You need to have the space shown ahead of the engine to make this work.
If you try it, good luck:dance:
Joker thanks for re-posting...I have all your pictures saved so when I get ready to go for it.
Oct 6, 2010
119
Beneteau Oceanus 321 Carters Pt.
Have a 3GM30F in our Beneteau 321,just replaced impeller yesterday about a 20 minute
job including replacing both belts
Tejas
Dec 15, 2010
164
Beneteau First 36.7 Lake Travis
We have had a SpeedSeal for about three or four years, and it has been well worth the money -- quick checks and impeller replacements, and no stuck gasket material to scrape off.
Jul 8, 2005
523
Jeanneau 389 Grosse Pointe Farms, MI
I have not figured out the value of the speed seal other than the knobs instead of the screws. Does it indeed reduce the wear of the impeller? If so, then it might be worth it.
reworb
Apr 22, 2011
234
Beneteau 311 Ft Myers Beach
There are two kinds of Speed Seal, the original and Speed Seal Life. The original just has the knobs instead of screws and an o ring (depending on your pump your may not need a gasket just the o ring). With the original you can change an impeller in minutes, this may not be the case if you have a "rear facing pump" like in some of the older Yanmars like my 2 GM 20.
The Speed Seal Life has the knobs, o-ring and a run dry bushing which the face of the impeller rides against. They claim this allows the pump to run dry for up to 10 minutes without damage to the impeller. I installed the Speed Seal Life. I keep my boat on a lift and always have about 45 seconds of run dry before the pump primes. I figured anything that makes the impeller last longer is worth it. The rear facing pump is not conducive to regular checks (boat is used year round so no maintenance season here). Nice well made product.
