I always wanted the raw water pump face plate to face forwards. There is a kit to do this but I didn't want to pay what they wanted and it made the pump stick to far forward.
I came up with this idea since my boat is on the hard for the winter and I'm having boat withdrawal symptoms.
I have a 3GM30f Yanmar engine.
I used the Raw Water Pump bracket from a 3YM30 Yanmar ($55).
It won't fit as is, but with one modification it will.
I also used the existing bracket with no modifications so if this doesn't work it will be real easy to swap back to the existing configuration.
So, I flipped the pulley, added a couple of spacers, drilled and tapped a hole in the new bracket, assembled everything and Voilà!
I should be able to use the existing hoses.
All I needed to do was maintain the 1 " dimension from the back of the mounting plate to the center line of the pulley. This was the original dimension.
See photographs for a better idea.
Update: added part number for bracket: part #128990-42151
