Angles through line organizers
102
Islander 30 Bahama Keyport
I'm about to install some line organizers on my deck and am working with some time spacing. Are there any rules of thumb or mins/maxs regarding the angle of the line entering the line organizer and exiting back to the cockpit?
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
The line will follow the curve of the sheeve in the organizer as long as the line does not rub anywhere.
Ray
Nov 8, 2010
11,386
Yes. Load on the block is a function of the turning angle. Loads get high FAST.
Angle-Load
30° 52%
45° 76%
60° 100%
75° 122%
90° 141%
105° 159%
120° 173%
135° 185%
150° 193%
160° 197%
180° 200%
Dec 22, 2012
102
Thanks, Jackdaw. I suspected as much. So the object of the game is to minimize the angle!
Ted
Jan 26, 2005
1,280
Jackdaw got it right. Minimizing the angle will reduce the load that the turning block will see. It's not necessary to decrease the angle but just be aware that the loads will increase so select your hardware accordingly. Hardware manufacturer's will specify a safe working load for their products. Use that as a guide when calculating loads.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
I think the key is to get the blocks at the base of the mast low enough to minimize the rubbing from a bad angle. These deck organizers are oriented for horizontal loading and any line that comes down at an angle from the mast is going to lose efficiency due to friction.
Feb 20, 2011
8,062
Angle-Load
30° 52%
45° 76%
60° 100%
75° 122%
90° 141%
105° 159%
120° 173%
135° 185%
150° 193%
160° 197%
180° 200%
Does this translate to increased user loads? Assuming good sheaves, of course.
May 13, 2013
29
Tayana 48DS Phoenix, AZ
No, that is the load on the block itself (bearings, mount, etc.) - the load on the line doesn't change appreciably. Look at the case of the 180 degree turn - with 100 lbs tension on the line, there are TWO 100 lb pulls on the block - one to the puller and one to the pullee :) - and this adds up to 200 lb of load on the block.
Hartley
Nov 8, 2010
11,386
Hartley
That's correct. Now there IS an increase in work load due to friction, and that's a function of the block design. Good harken/lewmar/etc blocks with a large diameter race will be much lower then a cheap one with a simple SS pin bearing. Sadly thats how many deck organizers are made. In any case minimizing the turns, while respecting good organization and fair leads is key.
