No I do not!! While the Rocna is built to a higher standard the Manson Supreme is not going to fail anyone any time soon. It is a great anchor for a good price.
I own and currently use a Rocna but the Manson Supreme IMHO is just as good a performer. I have well over 100 anchorings on both the Rocna and the Manson Supreme and both, save one incident with a string of lobster traps, has set within inches not even feet every single time at 100%. I never, ever thought I would see 100 for 100 sets with no issues. Both anchors are rock solid. Do you want to drive a Toyota (Manson Supreme) or the Lexus (Rocna). If I had to do it over again I might buy another Manson just based on the cost...
Just out of curiosity how are you setting your anchor? How much scope? The Fast Set is generally a decent setter, not exceptional setting but good, and is intended to set from resting on it's side. Personally of the older gen anchors I'd rather have a real Bruce (upsized) than a Delta but the Delta's are generally not a terrible setter? I agree a 22lb Delta on a 35 footer is way too small..
Should I lose the all chain rode or should I put a snubber and chain hook system on? How much snubber and what material?
Keep the chain but use a good elastic three strand snubber to prevent shock loading. The more stretch the line has the better..
Watch how this Spade sets in very, very hard sand. I drive my truck on this are and it barely dents the surface. The Fast Set will set similarly though not as well in this location as the Spade did..
Spade Setting Video (LINK)
