Anchor's Aweigh... I'm really tempted by the lightest anchor..
Sep 17, 2022
228
Catalina 22 Oolagah
Waffle House came with a fairly neglected Danforth style anchor. The chain and the rode thimbles are about as rusted as can be. Additionally, the anchor probably weighs fourteen or more pounds. Much heavier than the eight pound Danforth that served very well on three different windy lakes over the years. So, I've picked up the CD anchor roller and the bow pulpit hanging kit (I had the same set up on my previous boat sans bow roller. Now I'm weighing whether to go with the four or chose the seven pound Fortress anchor.
I sure like the idea of the lighter anchor. A Danforth style anchor is ideal for the bottom conditions of the typical river fed lakes I sail on. Any thoughts? Is anyone using a four pound Fortress on their boat?
George
The Fortress is a good anchor. I was a skeptic until I was on a boat with one. It literally glides forward to the bottom. It had very good holding power. The aluminum Fortress is, of course, lighter than a comparable sized Danforth. So choosing sizes should be by the Fortress recommendations with a safety factor.
I can't speak to how it does in a big wind shift because I didn't experience that condition.
Likes: Stu Jackson
Sep 24, 2018
4,652
Catalina 30 MKIII Chicago
I have a two pound anchor we refer to as a lunch hook. It works surprisingly well but I wouldn't leave it unattended
ShawnL
Jul 29, 2020
229
Catalina 22 3603 Calumet Mi
I can't speak to holding power -- we have a 15 lb fortress style we've never deployed (don't do that much anchoring) and a 10lb mushroom we use all the time. But we only really anchor for a swim or lunch, etc. Interested to see what other say -- I wish we could anchor out more, but we're older and the boat is just not as comfortable as our bed a short distance away.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
A lot depends how many nights you might spend at anchor and how far away you are from safe harbor.
The 7 pounder is only an extra 3 pounds and generally only three inches bigger. If you anchor out over night much and it can comfortably fit on the hanging kit you have I would go with it. You will sleep better.
On the other hand if you only go out for day sails and picnics I might go with the 4 pound model.
KCofKC
Sep 6, 2010
73
Catalina 28TR MKI 317 Smithville
George, a lot of the holding comes not from the weight but he rode angle as well as bottom composition. If you use the 7# Fortress with a bit of like 1/4" chain it will hold everything you have. I have used an 11# with 10' of chain and through the night holding a 6K boat it was deep in the sand and a good bit to get it up.
