C
Cool Hand
I am the proud new owner of a Hunter Passage 420 -- resulting in part from the advice on the thread "Should I buy a 420?" on this site a few months ago.The 2002 Hunter 420 Passage comes with a standard issue Lewmar Delta Fast Set 44 lb anchor with 20 ft of chain. I have so far anchored 4 times, and have had this anchor drag once in about 25 to 30 kts of wind (the highest we've experienced). This was in Chesapeake Bay mud, with probably not quite enough scope -- maybe 5X rather than 7X. As 420 owners know, the 420 tacks quite widely at anchor - going through at least 90 deg.My previous boat was a Catalina 36, on which I had a 33 lb Bruce. That anchor immediately set, ALWAYS held -- no exception, no question. Based on this experience, I'm considering going to the Lewmar Claw, being the Bruce knock-off at about 1/3 the price. Also rather than going to the 44 lb Claw as a replacementfor the 44 lb Delta, I'm considering going to the next size up -- the 66 lb Claw. I'm also considering going to the Anchor Sail as a means of reducing the tacking at anchor. My Questions:What experience have any 420 owners had with the holding performance of the standard issue 44 lb Delta?I'd be interested in the experience of any owners who have sweitched to the Bruce or Claw -- and hearing of the results.In particular -- any input on switching to a 66 lb Claw would be appreciated. I have an electric windlas which does a good job of stowing the Delta when it gets to the bow roller. Any insight on how the Claw would behave? Any experience with the Anchor Sail? There appear to be 3 sizes -- any insight to which size to use? They seem quite big, as in 10 ft X 10 X 9. Also -- the Hunter 420 does not have an aft stay -- any lessons learned on how to best rig the Anchor Sail?Any inputs will be appreciated.Thanks 224RCool Hand
