Anchoring (storage) a trailer sailor
Jun 10, 2024
323
Hunter 240 Okanagan Lake
I am preparing to spend some time with the anchor and rode on our Mac25. I do not have a storage area for it. I thought of a few things but I’m stuck on a bucket inside a bucket. I have 150’ of 3/8 twisted nylon 3 strand and 20’ of 1/4” galvanized chain. If I place the nylon in bucket 1 and drill a hole in the bottom of bucket 2, I can run the chain up keeping the two separate. I don’t want the weight of bucket 2 on top of the nylon though. My idea is getting too complex so I thought I would ask, what are other “no anchor locker” trailer sailors doing?
Other concerns:
I have a 10kg Bruce, bit over kill but a tad heavy for a 25’. It should hold well. Too much? I am a young 54 yr old, titanium clavicle 7 screws. Looking at 20’ anchoring depths.
The 3/8 nylon has a stainless thimble. I have a galvanized shackle? (We are likely fresh water only)
Storage on the vessels CofG would not be obtainable. There is an acceptable spot right behind a bulk head but it is more aft of the vessel?
Safety wiring the shackle pin would make storing the rode away from the anchor arduous. Will I ever be in a position where deploying the anchor must happen seamlessly and immediately? Have you?
5/16 shackle on a 10 kg Bruce?
2 shackles must be used to get the best motion at the anchor?
Thanks
pgandw
Oct 14, 2023
253
Stuart (ODay) Mariner 19 Yeopim Creek
I was storing my anchor and rode loose in a cockpit hatch in a tangled mess. And I'm usually single handed. I don't like anchoring by the stern especially in a low freeboard Mariner, I like to be headed into the wind to back down and set the anchor. Just didn't have a good arrangement. Then another Mariner skipper presented what he did.
I mounted my 8lb Danforth-type anchor to the bow pulpit with hooks on the pulpit. In the cockpit locker is a small clothes basket with 10ft of chain and 200ft of nylon rode. At the anchor end of the chain is a strong mountaineering style carabiner (yes I checked breaking strength of the carabiner to get at least as much as the chain) that I hook on to the anchor. The bottom of the basket has a hole with the bitter end of the rode so I can cleat it off before deploying. In relaxed circumstances, I simply go forward with the basket, tie off the bitter end, clip the carabiner to the anchor, and tend the anchor from the bow.
In real world single handing when it's not nice, before I leave the dock, I'll often bring the anchor back to the cockpit, and pre-run the rode through a forward chock and back to the anchor outside of the shrouds. I installed convenient midships cleats for both docking and anchoring. Probably will end up with a second anchor one of these days and do a similar rig for it.
Fred W
Stuart (ODay) Mariner 19 Sweet P
JBP-PA
Apr 29, 2022
824
Jeanneau Tonic 23 Erie, PA
Anchor plait stows much more compactly with less tangles than 3 strand. You can also get nylon webbing/ribbon anchor rodes that roll up on a reel. Ankorlina is one brand.
Practical Sailor has an article about boats without anchor lockers
I haven't much experience on my Mariner 19, with anchoring. Currently, I keep two anchors, one on either side of the CB trunk. It's the rode I keep forward, or will, when I've finished everything I'm planning to do to prepare Aquaria for overnight sailing.
Yes!
An anchor is an important piece of your emergency safety equipment. You may never be out in a situation where you needed to stop your drift towards a bridge or rocks, but an anchor could be the best solution to rescue yourself at times.
We lost our anchor during a storm in Mobile Bay one night, many years ago. It was a 60' S&S cutter, I was 14. The spare anchor was lashed on deck, under the dinghy. My father and I worked at getting that dinghy untied to get to the spare anchor, but we hit the sandbar before we got the dinghy shoved aside. We would have saved ourselves a mayday to the CG, had that anchor been ready to deploy.
-Will
One way to keep it neat is to make two coils - one for the length you actually need and another for that reserve section you might need. The reserve goes on the bottom of the basket, milk crate, bucket or whatever container works. The coil for what you will actually use on top of the reserve coil and anchor chain on top that and the anchor on top. The coil should be a flaked with some wraps around the middle to contain it.
I like the idea of pre running the rode from the anchor cleat on the bow to the cockpit where the rest of the anchor and rode would be. Deploying an anchor from the cockpit works as long as there is minimal forward way and the ancho is attached to the bow. For boats which don't have a usable foredeck a suitable turning block could be on the bow and the rode led back to the cockpit where it could be adjusted after deployment.
For short term anchoring, i.e., overnight or a few days, use a small zip tie to secure the shackle pin. Black ones are UV resistant. Emergency anchoring is a rare event, how much of an emergency really depends on the type of sailing you do and where you sail.
The shackle is usually one size larger than the chain, with a ¼" chain 5/16" would be fine. A larger shackle won't fit the chain.
One shackle is all you need. Adding a second shackle only introduces another failure point and more cumbersome. And don't bother with a swivel. I have hundreds of nights at anchor and never used a swivel.
Before you head out for an overnight, spend an afternoon or two practice anchoring. That way you'll figure out what works best for you and your boat before you have to anchor for the night or in a rare emergency.
Likes: BigEasy
Here is how I used to store my anchors on my McGregor 22. It would look better if I had used black PVC pipe. Later, I modified this by putting an endcap on the bottom with a weep
hole drilled in it and I would store 10 feet of chain inside the pipe already attached to the anchor. It’s a much better set up with the chain already attached and stored inside the pipe.
323
Wows, thanks everyone. Lots of reading to do. I really appreciate all of this.
2 weeks ago Michelle and I went out for an overnight. Our local yacht club has buoys set out around our favourite lake. We had troubles starting our outboard. She finally caught and away we went. We hoisted our sails and our outboard, turned itself off. No problem until the wind stopped. Long story short, fouled spark plug and towed by locals. Great experience. Lol
We were in a great spot to simply anchor down but we were unprepared. Our plan, practice anchoring safely and make sure we can do it.
Good plan, Steve. We learned to anchor on our C22 at Clear Lake, CA, during the summers when we'd trailer up from San Francisco. All summer the boat would be in a Clear Lake marina, but when we came up on weekends the marina rules did not allow staying on the boat in the marina overnight (this was in 1983 to 87). So we'd putter out of the marina on Saturday afternoons, sail around for a few hours and head up to the northwestern corner of the lake or the small bay outside the state park at the south end of the upper section of the lake and anchor out. It taught us a lot. Like anything else in sailing, it's practice, practice, practice. With a small boat and light anchoring gear, it's no challenge to spend a few hours one nice afternoon just anchoring, over and over again. I found the most important thing we learned was how to properly deploy the anchor. Don't just throw it overboard. We would slowly lower it until we felt it touch bottom and then slowly back the boat up with the engine while letting out more rode and only then "set" the anchor. I learned all these techniques pre-internet days from Patrick Royce's excellent book Sailing Illustrated. it is still available and I frequently recommend it to all new small boat sailors. Those techniques translate very well to the bigger boats we eventually owned over the next 35 years. Practice docking repeatedly one afternoon, too, 'cuz it's another one of those skills you'll need and that most people only do once a sail and then wonder why they're no good at it! :)
Sep 24, 2018
4,681
Catalina 30 MKIII Chicago
a 22lbs anchor will be quite heavy when leaning over the bow pulpit. On my last boat, I stored the anchor on the bow rail (you can buy different styles of mounts) and kept the anchor line on it's spool down below. I have line hooks all over the place on my current boat. I wouldn't hesitate to use one to store a rode if needed
Sep 17, 2022
232
Catalina 22 Oolagah
Wow. I read up on your lake, nice! I'm on my second C-22. My first was equipped with with a 3.6 kg Danforth style anchor. No chain, just 75m of rode. I kept both the anchor and rode in the starboard settee and when it came time to drop the hook, I dropped it off of the stern, walked the rode to the bow let it play out and cleat off at the bow. Then, back to the stern to back the engine down to ensure the hook was set. Easy peasy. After a number of years, I discovered bow hangers for the Danford anchors and that made weighing anchor a piece of cake as I did not need to bring the weight back to the settee until back in the slip.
On my current boat, I opted to replace the 3.6kg Danforth syle with a 1.8 kg Fortress anchor. Similar in style to the Danforth but with longer longer flukes and an adjustable fluke angle I will have more holding power with less anchor weight. The kit came with 4.6 m of chain and 76m of rope.
Now, one last thought. Since Waffle House is on a new to us lake, as I walk the piers down to my slip, I took note of the anchors others are using. Danforth style anchors are the predominant anchor on the lake I sail. What is the most used anchor style on your lake?
There is certainly nothing wrong with your current anchor. But, it is a lot of weight to lug around especially if it's windy or choppy. Your boat has similar displacement but more freeboard and length than mine so you might consider the FX-11 @ 3.2 kg as a possible anchor if you get tired of your current set up. Just a thought.....
George
Jun 10, 2024
323
Thank you so much for the detailed reply. I am a little worried about the weight guys. Danforth is definitely the dominant anchor here. There is another I see a fair bit of too but it was pricey. It looks similar to the Bruce but it has a half moon wire across the top to rotate itself. I believe Rocna but that may be the brand name. I actually have a Danforth I will take with us too. We’ll try setting each one and see.
Thanks again
I’d go with the Fortress. It’s light. It holds. It practically swims down to the bottom. I don’t know your lake but if a Danforth is good, a fortress will be better.
Oh dear, we are stumbling into an anchor thread! If the ground is muddy/sandy the Fortress will provide sound sleep.
There is no perfect anchor. Some anchors excel in sand and mud, others in rock, and very few in weeds. Danforth style anchors are a good general purpose anchor that holds well in sand and mud but absolutely suck in thick weeds. The only anchor that consistently holds well in weeds is the old style fisherman's anchor.
