anchor windlass installation
puppet
Feb 28, 2013
14
hunter 290 Pacific Playground
My body demands I install an anchor windlass! I have a Hunter 290. Hunter Marine not any help! Anyone out there with help/advice would be appreciated. Atalanta
Joe
Jun 1, 2004
8,304
Have you made an inquiry to the windlass manufacturer whose product you are planning to purchase? Do you have an anchor locker?
puppet
Feb 28, 2013
14
Good suggestions Joe. Yes to both. Manufacturers tend to give dimensions only. Even Hunter "refers" my questions.
Oct 29, 2005
2,366
Most windlass chain falls straight down, but for Hunter, and 290, I believe you need the chain to fall forward. Simpson Lawrence has option for lower part with cut-out in front for forward drop.
Apr 15, 2009
302
C&C 30 Annapolis
Can't speak for the Simpson Lawrence but a Maxwell VW10-8 mounted just aft of the anchor locker might be a viable solution.
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
There are some good threads on this subject on the Catalina 34 International Association website. Perhaps they might be of help to you.
puppet
Feb 28, 2013
14
Thnx Alex and Scotty. I'll follow up on both suggestions.
Atalanta
zeehag
Mar 26, 2009
3,198
i have a manual abi and an electric lofrans 1000....both function well.
make sure the hawse for the chain is directly under the gypsy, so chain goes directly into hole....helps to retrieve chain.
life is a lot better with a windlass.
