Lots of things to consider
Since you didnt fill out your profile, we have no way of knowing what boat you have. A 25KG anchor and 7/16" chain leads one to believe you have a fairly large boat, but then again, lots of people go for 'overkill' on smaller boats which is also a good thing. The normal 'swivel, shackle, chain,rope' rode with all being in good condition, usually has the swivel as the weakest part of the system, then comes the shacke, then the chain and finally leaving the rope as the strongest part of the system. When you get to the high dollar stuff, this order of strength can be changed. The best thing you can do is figure out what size system your boat needs and match your rode components accordingly. If you have a 25 footer, you have nothing to worry about. If you have a 50 footer, then conside your system individually based on safe working load (SWL) Tony BI'm still on my rant about filling out profiles. Whats the big deal? Taylor, I'm notr attacking you personally, I just think it would be so helpful when asking a question as it would be in responding to someone elses question. IMHO Tony B
