Anchor/steaming light
Rich
The vessel is a 1987 O'Day 272. Does the light atop the mast utilize one or two light bulbs (i.e. 2 bulbs/360 degrees all around for anchor and one bulb/225 degrees forward for steaming)? The DC panel indicates two positions on the switch (anchor/steaming). I ask this because the light is inoperative and the deck plug/harness is a four pin type (do all pins serve an electrical purpose?) Also,the boat came without an owner's manual and an explanation for the two position switch (sure wish I could arrange for a copy of one!). I feel the bulb(s) at the masthead are okay as they once worked and I don't like heights. Would also like to find a 90 degree version of the four pin plug, to replace the vertical plug, as the harness has been beat to death by the headsail clew on tack changes. I hope this is where the problem lies. Any help greatly appreciated!
Rich
Jun 7, 2004
350
Oday 28 East Tawas
anchor and steaming
Rich: The anchor light located at the very top of the mast is indeed a 360 degree light. While the steaming light is supposed to be located about half way up the mast. Finally there ought to be a spreader light or a combination steaming and deck light which has separate switches. I have not seen a steaming light located at the mast top but I suppose it might be allowed. I recommend you get one of the combination steaming/deck light units and wire it in accordingly. Good luck Mike
