Anchor Shackle
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
So my shackle on my anchor is 7 years old and was thinking about replacing….. a little rust on the pin but not so bad. 43 foot, 23,000 lb boat, 55 lb anchor and 260 3/8 chain.
One I’m using has been great (hasn’t broke!) but just curious before I buy a new one.
thanks
Greg
s/v Souleil
Dec 25, 2000
6,056
Hi Greg. Replaced the original swivel shackle on our 35,000 pound 1991 boat two years ago. It was due, but still held well even after many years of use. Went with a Crosby brand hot dipped galvanized swivel shackle from Defender.
capta
Jun 4, 2009
5,097
If you have even the tiniest doubt about that shackle, change it immediately. Why not, it's a cheap part and IMO, a boat's anchor tackle is the most important bit of safety gear aboard?
Jun 14, 2010
2,484
If you want to use a swivel the only one I recommend is the Mantus. Otherwise for a non-swivel I prefer Crosby or Chicago branded load-rated shackles (mounted so the pin is through the chain and the bow is through the anchor slot). Never non-branded shackles.
Apr 25, 2024
828
I would say that if you don't have any reason to suspect its structural integrity, there is no rush to replace it. But, if you suspect it, you might sleep better to just do it.
Likes: NYSail
Feb 10, 2004
4,245
Hunter 40.5 Warwick, RI
Always buy American made forged shackles like Crosby brand.
DO NOT BUY CHINESE SHACKLES!!
And always use two loops of safety wire.
This one was in service on a mooring for about 3 years.
NYSail
Jan 6, 2006
3,187
Yea though I had a photo but guess not. After 7 years the only signs of rust are on the pin….. and it’s not flaking or anything like the one Rich has a picture of. The rest looks fine. It’s a wll 2.6t….. I am a “why not change it” guy especially when it’s only a couple of bucks. And we always anchor. Just thought thought I’d see what others are using…..
Thanks
Greg
I have an opinion. “If you think it may need replacing, you are probably correct!”
I have a swivel made by Mantus. I felt it was a solid design.
